What is the best way to clean the toaster?
Is it safe to use chemical products when cleaning the toaster?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Alexus,
When cleaning you toaster, don't use any chemical products, that can ruin the exterior of your toaster. Cleaning your toaster is an easy task that just requires some time. If you want to clean the interior of your toaster (the crumb catcher and slots), check out this troubleshooting guide. If you want to clean the exterior of your toaster (the levers and knobs), check out this troubleshooting guide.
Hope that helps you out!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 497
