What is the max carry load for a 2015 Chevy Spark
What is the maximum load a 2015 Chevy Spark can hold (For example, what could the combined weight of passengers PLUS cargo be)
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Liz Pagel looks like the Gross Weight Limit is around 3014 lbs OR 1367 kg
Curb weight is 2246lbs / 1019kg – manual (LS model) and 2312lbs/ 1049kg – CVT (LT model). So if your model is a LT model then gross weight-curb weight (3014-2312) shows your total load can be no more than 702 lbs
このアンサーは役に立ちましたか?
Thank you, but I am looking specifically for how much weight can be inside of the vehicle (I.e. If there were three 200 lb adult passengers +cargo...)
Well Liz, simple math can help you. If you have 3 people in the vehicle, that's 600 lbs (200 lbs x 3 people). You then take that away from 3014 lbs and you have 2414 lbs left (2414 lbs - 3014 lbs). I'm not sure what kind of answer you're looking for. If the max weight is 3014 lbs, you then need to calculate it on your own.
I have a chevy spark and i load the back seats to the ceiling the tiny trunk to and i wiegh 200 my wife 250 and my dog rides in the front seat in the floor board so just us is 520 to 540lbs then all the stuff i have in there is aprox 300 to 400 each time i go i think im over the limit but oh well ive replaced 2 wheel bearings and a strut mount and a trans and engine mount too also the water tank for radiator is in the worst place on the motor mount so when that goes it will vibrate and crack the tank so ive replaced that to. I even go on off road hunting with my dog im sure youll be fine. Ps quiet but deadly my dog will hog hunt out the back window and jump out
過去 24時間: 1
過去 7 日: 5
過去 30 日: 13
今までの合計 3,837
