メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
it won't pick up service.
I have a iPhone 6 and it won't pick up service. It says it cannot be activated. Perfect condition and worked before. I was told it was the baseband, and possibly the antenna? Can anyone help me fix this? Apple wants $300 to fix it. I don't have the money for that. Someone help please!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
https://support.apple.com/en-us/HT201407
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Do a check first to make sure it's your baseband ic that's broken: When you remove the SIM card, does the phone alert you that no SIM card is inserted? If it does, then your baseband ic likely isn't the issue, and I'd suggest trying Omri's troubleshooting link.
If you remove your SIM card and the phone still continues to search for a signal, then you might have better luck taking it to a local phone repair shop instead of Apple. Baseband chip repairs require soldering (or you could try the "oven trick"). Either way, I wouldn't recommend it for a DIY project.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alexis Williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 101
