メインコンテンツにスキップ
Phone works but not in the house
My cell phone works great except when I am in my house. I have had the phone a little over a year with no problems. All of a sudden the screen goes black. Phone is still on as I can hear when I adjust volume, just can't see anything. When I go outside my house, the phone goes back to full color screen when I press the side button. Weirdest thing. I turned off all appliances & even turned off my main circuit breaker thinking something is interfearing with the signal. It didn't work. How could my phone work perfectly and then stop working only in my house?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
This may the auto screen brightness setting, as when your phone is in the sun it knows and will adjust the brightness high to compensate for the bright surrounding and vice versa for being inside where it is often darker.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If you have a modern android phone you'll wanna pull the notification bar down from the top and where you can see the brightness slider there may be a tick box for "Auto brightness" if you cannot find this tick box you'll have to navigate your way through the settings for the auto brightness setting.
Good Luck!
さんによる
コメントを追加
回答を追加する
Risa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 15
