Won't run a cycle
My whirlpool dishwasher will only cancel and drain. I can unplug it for 30 minutes and plug it in and it will run one cycle. When I empty and reload it won't start. I've done this for 3 days now.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
here is a link which shows how to run a diagnostic program on a Whirlpool dishwasher. Hopefully it will work on yours. If it does and you get a result click on the 'here' link in the page to see what the problem might be. If you need more help after that get back to us here. http://www.drdishwasher.com/troubleshoot...
If this is no good what is the model number of your dishwasher?
このアンサーは役に立ちましたか?
Whirlpool Quiet Partner III Dishwasher
Model GU2500XTPB6
Serial FS5310844
Hi Brenda,
Try this sequence and see if the diagnostic mode will run.
To start diagnostics, press the following keys in order in less than 6 seconds
Heated dry, Normal, Heated dry, Normal
To rapid advance the diagnostic one interval at a time, press the Start key
When you get to the end your dishwasher will be in normal mode again
Tried the steps suggested but it will not enter diagnostics mode
Model GU2500XTPB3 Serial FS1105772 Similar to above query Turned off power at circuit breaker and it re-try diagnostic sequence in a few hours
過去 24時間: 4
過去 7 日: 11
過去 30 日: 45
今までの合計 57,457
1件のコメント
@brendareeves hi brenda! I seem to be in the exact situation. Did you find a solution? There doesn't seem to be any other answers online
Ji kim さんによる
