How do you tighten the cable that makes it self-propelled? Personal pa
I can't figure out how to get to the cable under the mower to tighten it.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ray, if your cable is in deed adjustable, check the attached links and they will show how to make adj. A lot of self propelled models will need stretched cable assy. replaced as some have no adjustment or sometimes it is the stretched drive belt that needs replaced. Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=gYpW9t5b...
http://yardcare.toro.com/video/mower-mai...
このアンサーは役に立ちましたか?
There is an entire troubleshooting guide for tightening the cable as well as other issues that may arise here:
https://lawntoolslist.com/best-self-prop... and here: http://www.ehow.com/how_8758641_adjust-c...
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 28
過去 30 日: 124
今までの合計 24,974
