メインコンテンツにスキップ
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
220回答 すべてを表示
Which components from the original iPad mini are forward compatible?
Hello,
I have a fried iPad mini 1, logic board issue, no power whatsoever, and am considering buying a mini 2 motherboard so I can salvage it and make it realitivly usable again.
[read as 'want to build Frank-en-iPad']
I am curious as to which parts from the original iPad mini would be able to function normally with a logic board from a mini 2, just from looking at the logic board I can see that the battery connectors are different as well as the power, volume and vibrate switch connector.
Will the antennas, display, speakers, cameras etc function normally with the Mini 2's logic board?
Any help greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The digitizer can certainly be used. The LCD and rear case are not the same and those are the most expensive parts to replace. You'd be looking at roughly $125 just for those two parts. Some of the other internals are different as well.
Could you make a Mini 2 board work in a Mini 1? Maybe. Would it ever work right and would it be worth the money you would spend? NOPE.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Satan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 72
