iPhone 5s black screen but the screen works on other phones
iPhone 5s screen is Black but the phone works, and the screen also works on other iPhones. I really dont understand. Every help is really appreciated. Thank you
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I've just had a client that came in today with the exact same issues. I came into the conclusion that there is probably a display ic chip that has gone bad, not backlit because I tried flashing a backlight on the screen and could not see any image on the phone at all. All i see is the screen turning on (pretty much backlight is on but no display.)
I inspected the FPC LCD (front panel connector) and saw no signs of physical damage or any sort of liquid damage on the board, tried multiple screens, tested to see if the phone turned on which it indeed did and successfully booted up.
このアンサーは役に立ちましたか?
Maybe you over charged it
Try taking out the battery and clean out the insides with a dry cloth and leave the battery out for 5 mins and try and turn it on
Or
There is either a crack on the inner screen
このアンサーは役に立ちましたか?
Thank you for your comment!
But the phone vibrates When u charge him, how is it possible that it is a problem with the Battery? Also the screen works on other iPhones but not in this one so the screen Itself isnt broken i think.
You mean like ip display? Sorry I mean like you can display the screen on there devices
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 95
2 件のコメント
Perhaps the connectors one the phone are bad?
Imad Knight さんによる
Thank you for your comment, is it possible to replace them?
skilzz123 さんによる
