T7200 Intel processor on iMac 1207
Can I use a 2.0ghz T7200 Intel processor on this logicboard?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, the Intel Core2 Duo Processor T7200 (4M Cache, 2.00 GHz, 667 MHz FSB) is compatible.
I'm not sure its worth upgrading here as your system only has a 32bit EFI so it can't run any OS newer than Lion (10.7.5)
Also finding these older CPU's that are the try type can be tricky! Heres the IFIXIT guide you'll need to follow: iMac Intel 20" EMC 2105 and 2118 Logic Board Replacement it will only get you to taking the logic board out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 126
2 件のコメント
You either have a:
- iMac 20" 2.16 GHz Core 2 Duo with a Intel Core 2 Duo Processor T7400 (4M Cache, 2.16 GHz, 667 MHz FSB) CPU
- iMac 20" 2.33 GHz Core 2 Duo with a Intel Core 2 Duo Processor T7600 (4M Cache, 2.33 GHz, 667 MHz FSB) CPU
Dan さんによる
Can you tell us why you want to downgrade? I've done several upgrades but not the other way around.
mayer さんによる
