Charger is loose at connection port won't charge
Connection port won't charge unless I hold the cable a special way how do I repair this problem
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Susan, Tablet would have to be dismantled to access old USB port, USB removed or re soldered if not too bad from board or if old damage/worn a new one soldered into board. links below may not be your exact model but do show what is involved. If you choose not to do repair go to a local computer/cell phone repair shop and let them have a look and estimate repair. Check the attached links,instruction and guides, Good luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,679
