It is possible to change the SSD part of a fusion drive?
I Want to know if it is possible to change the SSD part of a fusion drive for a bigger one ? or at least upgrade the HDD with a data SSD.
Yes it is possible but it is very hard and should only be done by someone experienced there is a guide here is the link iMac Intel 27インチ Retina 5K Display Blade SSDの交換
このアンサーは役に立ちましたか?
That's not the right mac. That is for a 27 inch, the question is for a 21.5 inch.
There is no guide for the 21.5 inch but it is almost the same process there are tear downs for the 21.5 inch that you can use for reference. You can only use a fusion drive if yours came with one originally but you can change the hdd for a bigger one or a ssd.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 112
