R button working but sticking
My r button is working but it is sticking when you press it , it stays down and wo t come back up you have to press at the side for it to release again
Hi,
All the triggers below the L/R buttons include a micro-switch beneath the plastic cover.
My advice to you if to open it and clean with alcohol the micro-switch. This works in 90% of cases.
If still affected you will need to buy a micro-switch replacement remove the old one and solder the new one.
Good luck and good repair.
JM
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 29
今までの合計 1,667
