No video output, Cant change output mode, Can't hard reset.
Got a free PS3 that had three CDs stuffed in it and after removing them it was working fine (Stress tested, left running for about 6 hours and tried multiple game, also booted half a dozen times)
.. until I let someone borrow it and now there is no video output.
Have tried:
• Rebooting / resetting from wall, back switch etc
• Multiple monitors
• Multiple cables
• Using AV cables
• Changing video output mode (Holding down power button while AV is hooked up)(PS3 does not beep after holding power button for 5 seconds, after about 30-45 it will beep then shut off)
• Have Pulled apart a second time and checked all exposed plugs after taking top face plate off and nothing is out of place/not hooked up)
• Have cleaned contacts on HDMI port as well as possible.
I have a tech kit as I'm normally a computer / network tech so have many tools to sort this out.
Please help SOS
Are you sure your "Friend" didn't open your system up and take out a good part and replace it with a bad one?
Brian Reeder さんによる
It was a 14 year old girl. I'm %100 sure.
Omri Swarbrick さんによる
You can also just connect all video output options and then check them one by one till you find the one that is working.
Brian Reeder さんによる
Have the same problem tried the reset method by holding down red light power button for 5-10 sec NO BEEP... anyone figure this out?
J l l さんによる
