メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Why won't my iPhone 5s power up?
So about a day before my problem, I was using my phone and it was down to 1% battery and I was on my phone for a least 1 and half hour and it was still on 1% battery (my phone was on airplane mode) after that it died out. so then I waited till morning to charge it, but after about a hour or so it wouldn't turn on.
This has happened before, but after pressing the lock button for a really long time it powered up again. (but this time it didn't work)
Things I've tried:
- I tried unplugging it and switching from different power sockets.
- I tried charging it from my laptop.
- I tried pressing home + lock button.
I would appreciate any suggestions.
thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
connect to your laptop and hard reset the phone (press home+lock button for at least 10 seconds), also repeatedly. with luck it is detected again via usb in itunes also in restore or dfu mode > restore from backup
maybe defective battery
if it comes up check battery cycles with ibackupbot
http://www.icopybot.com/itunes-backup-ma...
If its above 500-600 cycles > replace
good luck ;)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
S orry, You didn't say you tried a different charge cord... dropped it, water damage even from sweat especially the 5S...
There could be damage to the charge port or internal components from using quick chargers or non ISO chargers.
I would suggest resetting the phone and update but only if you know the iCloud account, and never change a 5S fingerprint sensor and update your phone or it will get 'bricked'. You cannot swap FP sensors without programming from apple.
You can replace the charge port complete cable...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Don't forget to leave feedback if this helps.
Let us know the results.
It's easy to replace a battery, I buy several cheap ones rather than an overpriced original.
Always use Apple Chargers and not the cheap ones or Samsung for Apple. Your phone will develop glitches if proper chargers aren't used.
さんによる
コメントを追加
Update 2018 Dec.: I have an iphone 6S now, bought it for $60 as it wouldn’t turn on, having broken the screen of a newer 6S I traded from Kijiji. This Gold 6S, upon opening had signs of water damage both on top by camera and bottom at charge port area but no significant damage. Fortunately I had parts and could interchange that logic board and anything else. Cleaning the charge port itself (after disassembling the whole phone realizing the logic board wasn’t water damaged) I was able to get the phone working but the power drain was very heavy and the phone would reboot itself or shut off intermittently! There was no physical damage to the charge port electronics but inside the port itself where the contacts are there was an issue and I had to connect and disconnect it many times before it would take a charge at all and at first sat there for several hours only to get to 75%… Sometimes my phone would crash an then when it turned back on it would show Red 1% power then it would jump right back to 100 % or close to that! Everytime it said around 1% when rebooted.
So, Changing the Charge Port itself made this phone work perfectly and now battery life is Superb, charges properly and by the way there was a new replacement OEM battery in this phone when I bought it and the charge port itself was depleting it severely and causing crashes, and long periods before it would reboot and lengthy boots.
Jump+ tested this phone just prior to me purchasing it and claimed it as a logic board issue and the repair would cost owner $280.00 Canadian.
I had this phone booted in 15 mins and original owners were upset at Jump+ because they wanted their pics. Again I prove that Apple only wants to replace logic boards (worth more than phone itself) and they have no Jump+ staff trained properly enough to resolve peoples issues with iDevices. Unless you are under warranty I would take nothing to Jump+, Staples, Best Buy or anywhere that doesn’t get into actually testing the logic boards themselves with other known working parts! I have gotten Macbook Pro’s working easily that were deemed Logic board Issues yet turned out to be Track Pad and or Keyboard issue and sometimes a simple thing like a ribbon had water damage. Of course I clean logic boards and inspect things very closely. Most times there are visual clues that aid in resolving these issues.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
waves さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 184
