cant find repair guide on site
can you link this to me - i think it is either a dead battery or a bad board - it seems to be stuck in recovery mode if linked to itunes - other than that it will not even turn on....
Try holding down the home button while plugging it in this will bring it into DFU mode not Recovery and you might be able to restore. I doubt this problem is harware related as I have seen this problem solved many times by software means.
G'luck
Liam Speirs
このアンサーは役に立ちましたか?
Except of course for the fact that it won't turn on...
Ok so i did what u told me to do and that was to hold the home button and is said the same thing. it said ipod in recovery mode must restore then i tried restoring it and it said unknown problem occcured . do u have any suggestions.
このアンサーは役に立ちましたか?
Yeah, what liam speirs suggested probably would have done nothing, follow Ben Eisenman's advice.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,044
1件のコメント
Can it hold a charge?
rab777hp さんによる
