transmission on a 2011 torrece is slipping
transmission slipping.is it censor or computer problem.no codes except for wrench light tuns on/
If the check eng light is on and you can't see codes it prob transmission codes. If it's slipping it is not electrical it is internal. Check and make sure the fluid is full and also check the color and smell. It's supposed to be pink and clean. If it's black or brown and smells bad like its burnt then your going to need a new Trans or a rebuild soon.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 27
