My Finepix T310 won't turn on, battery is full.
Was working fine, then won't turn on, battery is full.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
William, Try a reset, remove the batteries and A/C adapter from the camera. Pull the batteries out and then put back in to reset the camera. This will reset the internal hard disk, possibly it had a malfunctioned.
If this has no effect you may want to clean all battery contacts and replace all batteries with new recommended batteries. Check the attached links,instruction and guides, Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 113
