メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Sensors defective? Compass doesn't work.
Hello, I'm using an iPhone 6 Plus 64GB which I bought 2 Years ago. I installed iOS 10.0.1 and 10.0.2 recently.
As I recognized now, the tilting sensor doesn't work anymore. The compass needle is pointing to north and doesn't rotate. I can't even calibrate the compass. Playing games with tilt controlling doesn't work. It's possible that this is broken since few weeks, I didn't used it for weeks.
Sometimes it works for a few minutes after a reboot.
I tried resetting the phone completely, setup as new phone and tested the compass. It still shows the same problems.
GPS is working fine, as well rotating the screen. It got never any water damage at all. I dropped it about 1 year ago, but nothing was damaged after this except a bigger scratch at the corner.
Which sensor is affected? Gyroscope? Accelerometer? Magnetometer?
Thanks for any support.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Upgrade to 12.2 fixed my SE. No idea why the compass and compass-related apps started acting up in the first place, but seemed to be software issue here.
さんによる
コメントを追加
15件の回答
最も参考になった回答
The compass won’t work if your iPhone is in a case with a magnetic flap!
The magnet freezes the needle!
このアンサーは役に立ちましたか?
スコア 9
6 件のコメント:
The phone wasn't inside a case.
さんによる
Correct. Thanks!
さんによる
Worked for me. Thanks!
さんによる
Exactly what happened!
さんによる
Amazing, you’re a legend! Thank you, the magnetic case was the cause, took case off and it’s working fine again
さんによる
1以上のコメントを表示
コメントを追加
My compass never worked. After trying a few things I finally went into the compass app settings. I turned off the "True North" feature and now the compass works just fine.
このアンサーは役に立ちましたか?
スコア 7
8 件のコメント:
Never got a worse answer.
さんによる
That actually helped me. Thanks Tom Jones.
さんによる
Nice, thanks, this setting was the problem for me as well.
さんによる
Thanks a lot! My compass moved but my north felt wrong, turned out to depend on having ”geographical north” in Compass Settings activated. Turn it off!
さんによる
Same here... turning off true north made the app work again. Thanks.
さんによる
3件以上のコメントを表示
コメントを追加
Had the same issue........Go to settings then to privacy then location services then to system services and turn on compass calibration.
Check the compass and it should be working.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
I just got a brand new 6s to replace an old 6, Had the same problem on that phone as well as this one out of the box. I followed your instructions and now it works...
さんによる
Thanks, worked after going DEEP into the settings like you instructed. Why does one have to go that deep in order to turn on the compass?? How would one know to do this with an App that comes with your iPhone in the first place? I think I used it when I first got my iPhone 6, but maybe after all the updates since new it has buried this setting now?
さんによる
Thanks, worked for me.
さんによる
コメントを追加
I had this problem too. I literally just gave my iphone a hearty whack to the palm of my other hand and the compass fixed instantly.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Excellent diagnostic tool. It read W / whacked / read N as it should and then when I opened MAPS it went wonky again.
さんによる
It wouldn't work in the case, so took it out but still wouldn't go, gave it a whack and its working, thank you.
さんによる
コメントを追加
Try swiping left on the compass app to display the surface leveling tool.
Turn the phone on its edge to display the edge leveling tool.
Swipe right to return to the compass to, hopefully, see an unfrozen compass.
Worked for my iPhone 6 running iOS 11.2.
Probably a software bug.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Worked on my 6 but not on my 6s, removed 6s from case & works, Thanx.
さんによる
コメントを追加
I had the same issue. It was the magnet on the back of my case.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Otter box case, no magnet.
さんによる
コメントを追加
Sounds like you did the logical steps... I'd put the iPhone in DFU mode and restore it(different from iTunes restore).
This would rule out possible software issues..
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Didn't know that DFU is still a thing in 2016. Will try this today. A downgrade to 9.3.5 is also possible I think, will try this as well to exclude an iOS 10 problem with my phone.
さんによる
DFU has always been a thing since iPhone 3G haha. Yep you can go back from iOS 10 to 9.3.5 as apple is still signing the ipsw firmware for that.
さんによる
コメントを追加
Tried an DFU Restore of iOS 10, same issue. After a RESTORE it worked for a few seconds, maybe a minute, but then the compass stopped working. If I shut it down and leave it off for few minutes and then starting it up, the compass works as well for a minute or so, but then stops working. Even with 9.3.5 I get the same problem. Both without the backup. Any ideas? Probably a temperature issue?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It happens with Touch Disease...It's on/same area of logic board that control touch. I disassembled my phone 4 times and put a shim where the solder joints loosen (known Apple issue) and you need to get it 'just right' or everything will work except the compass (can still rotate phone, etc).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I did something weird but it worked; since the problem is probably a magnetic needle I tried to rub a strong magnet at the back of my iPhone 6 after I tried every other option (except the DFU) and the only thing that worked is turning off the true north (which is unsatisfying cause I Shouldn’t need it in a perfectly well phone), so I rubbed the magnet real good and completely turned off the compass app and turned it back on and as I expected the compass was working but heading to the wrong direction until the ball in the circle appeared and after doing the recalibration it worked perfectly with the true north on !!!
  • I’m a bit of a chatty so I’m sorry if that was a long explanation, but I really hope it helps
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Update: it didn’t last long.
さんによる
This is a different problem.
さんによる
コメントを追加
It is the same issue/fix as the touch disease problem. You need to take the logic board out and put some folded up electrical tape on the chip that the solder joints come loose over time. I went nuts researching this issue and figured it out when I had to fix the touch disease issue. My compass worked again but I need to put more tape on the chip as the touch works fine but the compass died on me again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried all of the above but nothing worked. So, with the compass app open I gave my phone a really vigorous shake ….. hey presto, it works fine now
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I just shook my phone (with magnetic cover on), and now the compass works! Go figure....
さんによる
コメントを追加
Changing the front camera flex is the last answer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Still have this issue. It’s definitely software. Occasionally it goes away after an update but usually comes back with the next update. I can clear the glitch sometimes by rebooting phone with SIM card removed. It will also , oddly enough, clear up after taking a plane to another geographical area.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Added a Gotit magnet and it messed with all gyro features, compass, measuring and level. Remove from magnet and power off/on. Works again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lordimac さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 77,451
