Are the bottom pentalobe screws identical to those of the 6S Plus's?
Can anyone confirm are the bottom pentalobe screws identical to those of the 6S Plus's, i.e diameter and shaft length?
Thanks in advance.
この質問は役に立ちましたか?
Thanks in advance.
この質問は役に立ちましたか?
Same exact screws in both phones. :) Good luck!
このアンサーは役に立ちましたか?
Thanks a lot, I was confused for a little bit because apparently 6 and 6S have different shaft length (0.36mm vs 0.34mm).
Hello, i have the same question. I bought an aliexpress set with 0.8 pentalobe and i can´t open an iPhone 7 plus. The screws dont match with the screwdriver. The phone and screws are new. Any sugestion?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 702
