Charging port stopped working.
charging port stopped working. I cannot re-charge my kindle paperwhite. Has anyone had problem like this, and what can be done?
Thank you,
Sandra
この質問は役に立ちましたか?
Thank you,
Sandra
この質問は役に立ちましたか?
Sandra, sounds like you may have a loose USB port. Charge port is soldered to a circuit board inside the Kindle that allows battery to charge. If the soldered connection breaks, the battery no longer charges. If you google your problem you will see there was a problem with Kindles charge ports.
Small computer/cell phone shops can make repair/replace charge port, get an estimate, just a guess $30-$40.00. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 694
