car rough idles after engine swap to a 2002 honda accord v6
had to replace engine in 2001 honda accord v6 , replacement engine was out of 2002 honda accord v6 . when i got car back it has a rough
idle and almost shuts off.
You could check your fluid levels to see that they are properly topped up. Having low motor oil and other essential fluids might be causing unnecessary friction on piston heads.
A loose or slipping belt on the idler pulley might also be the reason. You can check for any major movement on the pulley wheels or squeaks coming from the belt to verify this.
Worst case scenario might be an engine problem such as losing compression in a cylinder, a damaged head gasket, or worn crankshaft.
このアンサーは役に立ちましたか?
I have rough idle also and it will loose power at any speed I need to pump gas to make it stop I get a code of p0132 and p1142 oxgen sensor. Before I replace it wanted to know if any one knows of a bad 02 sensor causing the car to act like this
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 134
