メインコンテンツにスキップ
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
Can't change default storage from SD to Phone?
I have a BLU vivo XL, and I have a micro SD card into it to expand my storage, but it has been downloading everything onto that SD card and now its full, I still have space on my phone but it won't install anything to the phone, only the SD card...Please Help. I have taken the SD card out and then installed stuff and it worked. But I can't change the default storage.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
Hi,
Check the following setting:
Menu > Settings > Device > Storage and see what the 'default' write disk is.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I have a special key for my Blu Vivo xl 2 and it opens the sim as well as the micro sd card slots it should com in your case. Also I a good way to transfer the partial information to your new phone is essential to not losing too much room as a confused waste in your phone's storage. Download an app if need be in the google play store.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Can you tell me how to open the XL2 to insert an SD card? I can't find an answer to this anywhere.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks! :-) Much appreciated. Do you have a specific app you recommend?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How can I transfer files from Phone to SD Card with my VIVO V7 mobile? Do I need to use PC? How about changing the default storage? It's so complicated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Levi Warkentin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 8,773
