メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
microphone on iPhone 6 not working
hi!
i have an issue whit an iphone 6 the microphone is not working either on regular call , handfree, or even bluetooth i tried replacing both microphone top and bottom
i also tried put on and off noise reduction soft reset hard reset ios update and DFU
so at this point i dont know where to look for to solve this problem
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Considering everything else you have tried it is probably an issue on the logic board somewhere, I would get someone who has experience with logic board repair to have a look at it.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
i sent an e-mail to ipad rehad i hope have news soon
さんによる
Did you ever get this figured out? I am having the very same issue.
さんによる
コメントを追加
Hey Old pal!
Heres a post I wrote on iPhone 6 microphone problems
If this dosent help I think you'll need to replace the ic on the board
Did you have any luck?
Blue skies
BT
Hope things are going well!
このアンサーは役に立ちましたか?
スコア -2
6 件のコメント:
@screenfixedau your answers are currently being marked as spam. On this part of the forum we let you help others by providing solutions. We do not tolerate linking to your own site, services or blogs. You can add those links to your profile and refer to that in your answers. You do want to stop that practice!
さんによる
@refectio @nick @alexniculescu I did not delete the question but did downvote it to give @screenfixedau an opportunity to review his answers. We do have to give anybody a chance to learn the rules before banning for Spamming. Consider to reverse your vote in moderation until we recognize which way the user is going. If it is going to be a habitual spammer I will delete this answer immediately
さんによる
@oldturkey03 yeah, I initially marked if for moderation but then noticed that the contributor had done it several times yet was clearly trying to help. That's why I brought it up on meta. However, I think mayer dinged him already...you might want to consider changing that.
Hopefully Ben will continue to contribute.
さんによる
I've reversed mine this time @oldturkey03. I may not do this a second time.
さんによる
@nick your call. You do not have to do anything anyone tells you. It was a suggestion not a demand.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Reparactif さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 313
