My optical drive will not read disks
i just built my computer and when i put the windows installation disk in i noticed the optical drive would not read disks this is the third optical drive i have tried none of them will read disks the first one died on another pc i know because i used it on my new pc build the second one opened closed and the light turned on but would not read disks the same with the third one i hooked the power supply up to them and i connected the sata cable to them and to the sata port on the motherboard and none of the optical drives will read disks and i was in the bios and saw that it detected the optical drives but im still faced with the problem that it will not read disks all of the optical drives i have tried are the same type an lg gh24nsc0b oem so is there anything more i can do?
この質問は役に立ちましたか?
15 件のコメント
Hi, Can you prove that any of the drives will work in another PC? It seems strange that you have at least two drives with a possible 'dirty' lens problem but you never know. Try cleaning the lens in the drive (Google it if unsure on what to do) and see if that is the problem.
jayeff さんによる
will those optical drive laser cleaning disks work without an operating system?
chris さんによる
Hi, I'm fairly sure that it wont. Here is a link that shows how to dis-assemble a ODD to clean the lens. https://www.youtube.com/watch?v=DZkCN_yx...
Have you tried one of your drives in another PC to prove it one way or the other?
jayeff さんによる
well i only have one working desktop
chris さんによる
and where can i find "spirit" in the video the guy says it is needed to clean the lens
chris さんによる
10件以上のコメントを表示
