メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Studio 2.0有線ヘッドホンの修理情報です。2013年に最初に発売されました。モデル番号はBT OV STU BLKです。
Speaker crackles and pops
So this has nothing to do with the 3.5mm cable but the speaker itselft. My left speaker crackles and pops when i move around. Very annoying to listen to music and walk since music on left side stop and crackles. I went to a repair shop and they said if they try any harder they could break the whole thing! Don't know what to do now. Any suggestions? Would local apple shops be able to fix this? Or do i have to send it off for it to be repaired?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
Anybody manage to get a handle on this? I have the same problem
さんによる
YO YO YO, I FINALLY SOLVED THIS , I KNOW YOU PROBABLY GOT ANOTHER PAIR OF HEADPHONES BUT FOR THOSE OF YOU WITH THIS PROBLEM
Its the way the ear cup folds , NOT THE BAND ! the ear cup is what I’m referring to.
Put a hair tie in the middle behind the earcup and the stem ! IT WORKS I SWEAR ON MY LIFE !!
さんによる
omfg omg it works! What? I tested it out and yes, my right one was at a different position than my left one!!
さんによる
コメントを追加
3件の回答
ベストアンサー
Joshua a bad cable/connections could cause speaker clarity issues, if your positive not the cable, probably best to contact apple support or at least check out their trouble shooting guide.
Check the attached link,instruction and guides, Good luck.
https://ca.beatsbydre.com/en/support/tro...
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
i'm definitely sure its not the cable as i tried 3 different types of working cables. Thanks for the suggestion. I'll try your link
さんによる
Had the same problem. Even opened up the shell and checked the wiring inside. Seemed not to be the problem. After closing everything up, I found out that when you put pressure on the shell, pushing it away from the headband, the crackling stops. So I wrapped a peace of rope (5 mm. thick) twice around the shell. Downside: the shell can't move anymore. Upside: the crackling is gone.
さんによる
hello i have a problem quite similar but not exactly, my beats studio 2.0 works perfectly fine ...WITH EVERYOTHER DEVICES THEN MY PHONE! i own a gakaxy s9+ and everytime i try to listen to something i hear kind of a buzzing / crakling sound in my left ear. not sure really what to do with it.... i had this beats for more than 5 years and nothing but now with that phone i cannot even hear a whatsapp message without this crakling sound. any suggestion?
さんによる
コメントを追加
I've had this problem too when listening while my phone was charging. I unplugged the lightning cable and the popping went away.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Your coil within the speaker driver may have popped out. If that's the case you can get it repaired. We sell the part and service if you need help reach out.
https://www.joesge.com/pages/repair-serv...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joshua Serban さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 38
過去 30 日: 125
今までの合計 19,256
