メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
87回答 すべてを表示
replacing headphone jack IPod mini 4gb
Replacing the headphone to main logic board, can't seem to make the connection to main board, still no audio out on ear phones.
My question " where is the connection made from earphone assembly to main circuit board?" Went tru the procedure as per instructions of installing, but without success.
When ipod is connected directly to ipod female Jack on Radio works perfectly.
Would appreciate help.
Thanks
CAOD
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
選択されたソリューション
Hello!
DO I understand this correctly that 1) your iPod works fine through the dock connector on the bottom, and 2) you cannot locate the connection on the logic board to plug the headphone jack cable into it?
If so, it sounds like an all-too-common problem with the iPod Mini: the headphone connector pulled off of the logic board. If you look at the headphone jack cable, is there a piece of plastic stuck on the connector?
If you look at this picture, the headphone connector is the black rectangle on the edge of the top left of the board.
If this connector is missing, you unfortunately need a new logic board.
Sorry!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
BEN,
thanks so much for your help. I was under the impression that when you inserted earphone jack into the logic board tru the top of unit that it connected to the logic board.
Again thank a million.
Happy New Yr 2010
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
charlesaodonnel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,817
