メインコンテンツにスキップ
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
42回答 すべてを表示
Why won't my tablet take a charge.
I changed the battery with a brand new one cause the old one wasn't holding a charge any more. Now I can't get the new battery to charge at all. I checked the charging port to see if it was damaged but it looks good. Do I have to rest the table back to how it was when I got it ? Don't know what else to do.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
please check the another outlet . If all else fails just walk into a Verizon store and tell them what's going on. They are usually pretty helpful in getting a replacement device for you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if your tablet has a micro usb charging port , they tend to get a bit touchy after a while. you might try and place the tablet on a flat surface and put something under the plug to apply a little pressure on the connector . trying it with the tablet face up or face down. those jacks seem to all get touchy after a while.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christine さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 765
