Not recognised in computer
Charges fine, tried multiple laptops/leads etc
Any ideas what it could be except charging port? obviously don't want to have to replace that because it's a massive job for something so insignificant
David,
There is a software setting in the phone to force it into "Charge Only" mode. Maybe it is stuck in that mode? My old droid phone would ask when it was plugged in. Does yours prompt you at all when you plug it in to a computer? If not, then it's probably the port on the phone is bent out of shape and not getting a good connection. I personally think the micro-usb jacks aren't very well designed. Probably would need to replace the daughterboard or resolder on a new female connector. Instructions for that here.
Best of luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 53
