not charger please help me
i have Dell Inspiron 8600 not charger please help me thank you so much your answers..........
If you have the laptop, but not the charger; you can find replacements all over the place. One place I use (and highly recommend) for Dell parts is http://parts-people.com (http://www.parts-people.com/index.php?ac... if you want a charger for your laptop). If it is another issue; could you please post additional details?
このアンサーは役に立ちましたか?
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repai...). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,008
1件のコメント
Need more information to help you. You don't have a charger? It's not charging? Number of Cycles on the battery?
originalmachead さんによる
