ringing is too low
how do turn up the ringer?
To raise your ringer volume
The base has three ringer volume settings: high, low, and off. You can change the
ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([H, ] High, [Lo ] Low, [ OF] off) (if you set the
base ringer volume to off, “Ringer off” is
announced) and it is displayed on the base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
このアンサーは役に立ちましたか?
Ringer is too low, and not often enough
My ringer is too low.
過去 24時間: 4
過去 7 日: 17
過去 30 日: 131
今までの合計 4,548
3 件のコメント
Ringtone and volume is too low
God Gifted さんによる
@God Gifted
What is the model number of the phone if not a Uniden D1760?
jayeff さんによる
Which is the ringer key?
carol gawlak さんによる
