メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
371回答 すべてを表示
Where are Temperature sensors on MacBook air 13 2012
Good afternoon. Faced with the problem of spontaneous reboot my laptop MacBook AIR 13 mid 2012. Diagnostic Utility gives an error: 4sns/1/s0000008:Th1H-124. The service is proposed to replace the keyboard and trackpad. Who can tell where there are temperature sensors, whether such a procedure will help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
i am sure there is some code to get these to display or even extract some kind of log of the temps but even better you could get software that will tell you real time temps. personally i use istats, i get all kinds of info worth the 15 some odd euro i paid for the app
さんによる
コメントを追加
2件の回答
ベストアンサー
Problem was solved by replacing the keyboard, and the replacement of temperature sensors in the touchpad. Because seizure off button on the keyboard, has constant reboot. Fix the keyboard failed, it had to change. Errors in temperature sensor touchpad led to the CPU at 300% Repair went much cheaper than the official service.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
You'll need to install an app which accesses them. Here is what I use: TG Pro for less than $20 its worth it!
Once you have it installed it will show you more clearly whats going on here. Post a screenshot on what it shows you.
To help keep the system running a little longer, try putting your system into a plastic bag squeezing out all of the air and putting it into the refrigerator (not the freezer!) Don't leave it in more than an hour.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
stierus さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,733
