メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
71の回答 すべてを表示
Screen flickers and goes black except when minimum brightness is set
I love my 24" LED Cinema Display and it has been working great until a couple of months ago. I started noticed that it didn't turn on after sleep but I finally found that it started working again if I dimmed the screen a notch. That problem sort of increased and now it's only working when it's set to the minimum brightness. If I increase the brightness it starts to flicker and then after a couple of seconds it goes black.
Everything else works as expected (USB, Camera, Charger etc).
Anyone with and idea on how I can fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
The backlight it most likely dead. Set the brightness to the maximum, then when it goes black, point a flashlight at the display and see if you can detect a picture. If so, the backlight is almost completely out the window and can only deliver a very little amount of light. A quick Google search comes back with many useful results here.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jon さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 248
