Batterystatus frozen on 100%
Hello,
I changed the battery of my iPhone 5c. After the replacement the batterystatus worked. But after recharging it its frozen on 100%. I already updated the new ios and also reset it.
Then I turned it on with the old battery but it's still 100%. Does someone know how to fix it? What was my fault ?
Thank you!
Update (08/29/2016)
Here are my results it seems that there are now parts missing.
Maybe the power management ic is corrupt ?
Update (08/29/2016)
Some more
Update (31.08.2016)
I read out the batterystatus with "ibackupbot" and I got these informations
'' CycleCount: 1
DesignCapacity: 1584
FullChargeCapacity: 1600
Status: Success
BatteryCurrentCapacity: 100
BatteryIsCharging: true
ExternalChargeCapable: true
ExternalConnected: true
FullyCharged: false
GasGaugeCapability: true
HasBattery: true''
The weird thing is that the batttery says that its not full charged but its still says 100%.
The other thing I found out is, if you look at the pictures from the microscope, you could see that there is something on the logical board on the left side, maybe the battery lost some liquid and connect some parts to the ground. I couldn't finde some other pictures of the logical board under a microscope, so I will try to clean it up tomorrow.
If you have some other ideas please let me know.
Thank you!
この質問は役に立ちましたか?
2 件のコメント
Try leaving it unplugged until it turns itself off, then charge it until it turns on. From what I understand, iPhone batteries have to be calibrated to sync with the on screen readout, otherwise iOS doesn't have a baseline from which to calculate the level. I believe letting the battery rundown all the way then recharge it should reset the battery level in the software. Granted, I have only read about it online, so if anyone has more practical experience working on the iPhone, I would appreciate a fact check. (this is more of a recommendation of where to start looking.)
Ben Eccles さんによる
Thank you. I tried this also but when the phone turned off and i connected it to the charger there was 1% for a moment and then 100%. I also read about what you said. Never made some practical experience too.
hehe0903 さんによる
