Computer won't turn on after replacing memory and battery
After replacing the battery and the memory my computer won't turn on. When I went ahead and put the old battery and memory in it also wouldn't turn on. I feel like I might have done something during the installation process that has caused the computer to not work. I believe I might have switched out the ram while the new battery might have been plugged in and if that's the case and I shorted it, what can be done now?
Any tips are appreciated
7 件のコメント
Does it draw power from the charger?
echow2001 さんによる
When I plug the charger I see a green light. I also see a green light if I have the battery removed. Hope this answer helps.
khaledatti さんによる
does the fan spin at all?
echow2001 さんによる
You may want to check out Louis Rossmann on Youtube with his videos regarding the onewire circuit and power rails.
echow2001 さんによる
ok try taking out the ram and battery and disconecct power adapter, Now press the power button keeping it pressed for 1 min the put it back togerther and try again. Aso have a look at the ram slot to make sure you have not damaged the slot/pins.
Gary さんによる
2件以上のコメントを表示
