My phone is not able to make or receive calls, why?
But Sim Network Showing Properly.
Despite being connected to the network, I am unable to make calls or receive calls on my HTC Desire 816 Dual Sim.
When I try to make a call, the phone immediately shows "call failed" even without any ringing.
When others call my number, they report that my phone is 'disconnected or Out of coverage area'.
What is wrong? How can I correct this?
Hi,
Has the phone worked properly before? Have you tried your SIM in another network compatible phone to prove that it works? Have you tried another known working network compatible SIM in your phone?
jayeff さんによる
jayeff Thanks
same SIM used another phone working fine.....and any other SIM used same Issue.
Manoj Vinchu さんによる
Hi, Has the phone worked properly before? Have you tried the other SIM slot (use network manager to turn it on) and see if it works?
jayeff さんによる
Was this problem solved? I am facing same issue. Please advise on any solution
Tejas Mistry さんによる
