How much does it cost to fix fried power socket or battery
Hey, i recently put my iphone 5c on charge, it was a faulty cord but i started to smell smoke.. i unplugged it and yeah how much would it cost to fix it??
The cost of the repair isn't something that anyone here can quote without seeing the phone. It could be something as simple as a bad battery but more than likely its a filter or IC that blew. The smoke is the part that makes me question it being an IC or filter. I can't say I have ever seen one of them give off enough smoke to be able to notice it....but I guess its possible?
I would pull the screen and inspect your battery. See if its bloated or torn or leaking. If it is, its a very cheap and easy fix. If that doesn't work, take it to a reputable local shop.
このアンサーは役に立ちましたか?
iT DOES NOT SOUND SO GOOD, YOU CAN CALL APPLE, SEE WHAT THEY'D CHARGE YOU, BUT IF IT SMOKED IT'S PROBABLY FRIED NEARLY EVERYTHING IN THE PHONE... I THINK IT WOULD BE CHEAPER TO POSSIBLY BUY A NEW ONE... CHECK WITH A LOCAL APPLE QUALIFIED REPAIR CENTER, LOCAL SHOP ALSO....
このアンサーは役に立ちましたか?
all caps are not necessary.
Apple doesn't fix board or power related issues. Also, there is no such thing as an Apple Qualified repair center.
Your answer was less than helpful.
sOMEONE LOCAL THAT CAN REPAIR IT, THAT'S WHAT I MEANT, SOME LOCAL SHOP THAT IS KNOWN TO FIX APPLE PRODUCTS...
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 204
