Large heat sink, where does the fan go?
867 MHz DP bumped to 1.42 GHz
With the 1.42 GHz processor, it has a very large copper heat sink?
So where does the fan go, or does it need a special fan?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The fans should already be in place, The CPU fan is mounted in between the hard drive bays, and the Optical Fan is on the door. There is no fan attatched to the CPU heatsink Itself.
このアンサーは役に立ちましたか?
On my 867 MHZ there are (3) fans, one on the door, the system optical fan, one between the Hard Drive bays, and one on top of the heat sink. So no fan on top of the hint sink?
correct on no fan on the 1.42 heatsink
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 767
