メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Charging symbol is there but won't increase and sometimes decreases
My phone is plugged in and has the charging symbol but the percentage won't increase and sometimes decreases. I have tried using a different charger but it has no effect. I've left my phone on charge overnight but it stayed the same percentage as before I went to bed. Sometimes I see the percentage jump around (eg. From 26% to 20%) even when it is on charge. Once I noticed it was in the 20%s and ten minutes later was on 1%, all while being plugged in. I've had the phone for 1.5 years and it has never been serviced. Should I take it in to the apple shop and get a new battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hi, sounds very likely just a bad battery. First swap the battery to rule that out....make sure it's original if possible. Then swap the charging port to rule that out. If those both fail it's most likely your tristar chip on the board. Are you using original or aftermarket chargers?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi. Sounds annoying that it won't charge.
Well, first of all, be sure to check that the chargingcable isn't the problem. Buy an original Apple Lightning cable.
Double check, that it isn't the lightning connector, that is broken. It's quite hard to say, so if you where me, i'll fix it myself and get a new one. It's cheap, and nearly easy to fix. I'll give it a shot. Lokk here for a Lightning connector replacement.
Still, if that didn't work, try replacing the battery. But, it sounds like it isn't the battery, that isn't the problem. Lokk here for a battery replacement.
Well, because it's over 1 year old, the warrenty isn't there anymore.
Wish you the best luck, cheers.
iPhone 6 バッテリーの画像
ガイド
iPhone 6のバッテリーの交換
難易度:
中レベル
30 - 45 minutes
iPhone 6 Lightningコネクターアセンブリの画像
ガイド
iPhone 6 のLightningコネクターアセンブリの交換
難易度:
難しい
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Summer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 7,490
