メインコンテンツにスキップ
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180回答 すべてを表示
LG G3 cant charge unless I have cable at a specific position
Hi All,
My LG G3 is about 2 years old now and it doesn't charge all the time with any cable unless I position the phone/cable connector at a very specific position. I've tried charging a different Android phone with the same cable and it may charge but doesn't always charge the G3 unless I wiggle the connector till it charges. Maybe the charging port in the phone is worn out and needs to be fixed? If so are there instructions on how to do so?
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Ok thanks. BTW had a look inside with a flashlight and it seems the port is corroded. Will get it replaced. Thanks for your feedback,
さんによる
Note that the charger port is soldered onto the board so it is not easily DIY replaceable.
さんによる
コメントを追加
1 件の回答
ベストアンサー
That definently is a charge port issue. Get a needle or something and get out any debris in the port. If that doesn't work, you will have to replace it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
frsonn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 104
