2015年9月25日に発売。モデル番号はA1688 / A1633。このデバイスの修理は、前世代携帯と同様にスクリュードライバーといくつかの工具が必要です。 GSMまたはCDMA、16、64、128 ギガバイト有り /シルバー、ゴールド、スペースグレイ、ローズゴールドのカラーオプション有り。
1894の回答 すべて表示
Phone recognises Sim Card, sees number but says "No Service"
So I've received an iPhone 6s which was water damaged.
After having had it through the ultrasonic cleaner I turned it on and it all worked, at least that's what I thought.
The issue is that the phone recognises the sim card inside, shows me the phone number in iTunes and even tells me that I've inserted a wrong sim (its locked).
But after inserting a sim card it goes to "Searching" and then within a couple of seconds goes to "No Service".
I've replaced the antenna on the device and still nothing.
Any advice would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
That's exactly what I am trying to work out before I start taking off the emi Shields.
I tired ringing that number from my phone and the phone just crashed, not sure if that's related but that's what happened.
Everything works perfectly so I assumed it was just the antenna (it did look worse for wear).
There seems to be something obvious that I am missing.
I guess it will be the emi Shields next
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
5回答
最も参考になった回答
This is probably a stupid question, but do you actually have no service? If you do, take off the emi shields and check for burned components, especially around the baseband.
この回答は役に立ちましたか?
スコア 2
コメント:
Also, make sure the sim is activated and provisioned for service. Usually when the baseband is damaged, it will be stuck on "Searching" and not show "No Service"
による
Thanks guys for your answers.
I know it's not blacklisted as I've checked the iMEi, I also know the Sim is activated as I use it as a test sim in other devices.
I will open up the EMI Shield and have a play with that stuff and get it through the ultrasonic cleaner again.
による
コメントを追加
If you recently bought the phone there is a chance it could be blacklisted. The phone will act like this if the IMEI has been blacklisted by the carrier.
この回答は役に立ちましたか?
スコア 1
コメント:
I have a blacklisted iPhone 5 and it works fine with a sim and shows service.
による
Depends on your locale. In Canada, if it's blacklisted the IMEI is refused when registering on the network. Cheers for the downvote tho.
による
Sorry, I didn't know that. I live in the us. Un-downvoted. :)
による
Cheers, thanks! It's been getting crazy up here. You can hardly buy used anymore because people can still blacklist the phone days after you register it in your account!
による
コメントを追加
An update to the PRL settings may be needed
この回答は役に立ちましたか?
スコア 0
コメントを追加
I've had a similar problem with a iPhone 6 i was working on, i think it ended up being a fried coil or something, definitely a hardware issue
この回答は役に立ちましたか?
スコア -1
コメント:
its never the coil
による
all i know that it was a component on the board that caused the issue, was last your, dont remember how the guy fixed it, just sharing what i know
による
コメントを追加
The iPhone could be locked to a specific network like O2 or EE so your sim would not work with the phone until it was unlocked
この回答は役に立ちましたか?
スコア -2
コメント:
If it was locked it would say sim not valid.
による
sometimes it does sometimes it doesn't i have a iphone 6 with an O2 sim in with no service but it doesn't tell me the sim isn't valid
による
コメントを追加
回答を追加する
robertolejnik1986 さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 76
今までの合計 3,266
