Is there a larger, faster hard drive?
For the original MacBook Air Model A1237 1.8 GHz with an 80 GB 4200 RPM disk drive does there exist a larger and faster drive that can be used to replace the original? Or is the Samsung HS12YHA 120 GB 4200 RPM the only game in town?
Thanks in advance!
5 件のコメント
In the picture of the hard drive replacement you have for the original MacBook Air Model A1237 1.8 GHz with an 80 GB 4200 RPM disk drive iFixit shows a Samsung HS12YHA 120 GB 4200 RPM disk drive. However, when I visit the Samsung site for the HS12YHA at HS12YHA specs it indicates that the drive is a 120 GB drive with a PATA/ZIF interface and a spindle speed of "3600 RPM class" (really not happy about that) with dimensions of Height: 5.0 mm, Width: 71.0 mm, Length: 54.00 mm. So question 1: Is this drive a 4200 or a 3600 RPM drive?
danno さんによる
I'm looking at he guide to replace the drive and seeing a HS082HB/A: MacBook Air Models A1237 and A1304 Hard Drive Replacement
Could you give a link to what you're referring to?
mayer さんによる
With the Samsung HS12YHA I think he is referring to the drive being sold by ifixit.
[リンクされた製品が存在しない、もしくは無効: IF107-073]
R Trent さんによる
Looks like I messed up on an earlier answer and they messed up on the drive. I'm tired tonight so maybe someone else can locate a suitable replacement drive.
mayer さんによる
I've emailed my rep at OWC for an answer on this and invited her to answer here. SO don't downvote her if she posts an answer ;-)
mayer さんによる
