メインコンテンツにスキップ
The 2003-2005 Pontiac Sunfire is a more streamlined updated version of the popular car.
7回答 すべてを表示
My car won't run after bypass attempt
My car 2005 sunfire was running until I lost the keys. I drilled out the ignition so I could replace it instead of waiting for the new ignition to arrive I attempted the bypass scenario with failure.I forgot to disconnect neg side of battery. Its still not runningcant really keep the battery charged long enough to trouble shoot
My three wires to the ignition are WYB I USED THE yellow cut it tried the only resistor I had at the time. New ignition is in the wires are together . I tried the 3step 10 min I checked all fuses relays there good. Coil pack is firing . I need help please
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Anti theft is working well . you need a new key and tumbler and it will need to be programed in to work.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
James stevens さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 267
