My 03 ford ranger died and won't start .
Changed coil pack, plugs, cam shaft sensor, crank sensor. It turns over but won't fire. Has spark, fuel, and air. Maybe flooding injectors, wide open.
have you changed the mass air flow sensor
このアンサーは役に立ちましたか?
Mass Air Flow sensor wouldn't cause it not to start.
Replace your fuel pump relay and see if that does the trick. If it doesn't work you can return it and put the old one back in. If that doesn't work you can replace the fuel pump. A big red flag for the fuel pump or relay is if the car will sometimes turn over but other times it won't.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 640
Have you tried a code reader on it ?
tcagle53 さんによる
