メインコンテンツにスキップ
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
103回答 すべてを表示
MMS message's not sending or downloading
My phone, Alcatel One Touch Idol 3, will not receive or send MMS messages. It will just continue to say downloading until it times out. Is this a simple setting that needs corrected?
Thanks in advance for your time and help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 12
13 件のコメント
I also have this problem, my Alcotel will not receive or send MMS messages.
さんによる
Can't download a picture that I was sent
さんによる
Hello my name is Gene and my phone was acting up one day and I tried to reset it and even called to get help to reset my phone and so far everything is fine but now I can't text pictures from my Alcatel Android insurance wireless government phone and I think when I tried to reset my phone I must have done something on my end of the phone like with Google back up but I'm not sure what I did so can you tell me what I need to do thank you and have a great day
さんによる
Hello my name is Gene and if anyone can answer any question I posted on here then email me your answer at trappgene7@gmail.com
さんによる
I tried this solution but it doe's work for me.
さんによる
8件以上のコメントを表示
コメントを追加
5件の回答
最も参考になった回答
I had the same problem and T Mobile told me to do the following. It worked for me. What you have to do is turn on the DATA in your phone when you want to receive the message (even if you don't pay for data on your phone). Click on SETTINGS->MORE or Scroll to Mobile Networks (or just Networks) -> turn on DATA CONNECTION. You might need to turn on DATA ROAMING as well (same location). Watch out, once you turn on these settings your battery will drain like crazy. I only turn on the settings so I can download the image or whatever, and then turn them off. Also, make sure you are using the MESSENGER app that comes with the phone, and not an app you downloaded from somewhere else. HTH.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
worked for my son's phone
さんによる
My data and data roaming stays on and it still will not send or receive pictures
さんによる
I can send and receive mms with all my data turned off it does not affect it but my wife phone is through assurance and she can not send or download a 39kb mms message
さんによる
コメントを追加
so one solution to this issue is to reset the network. in this case you need to go to netwrok under settings hit mobile network. then the option of access point then it should only show one. what you desire to do imn this situation is refresh it by clicking the 3 dots in the upper right corner of the screen. The option of reset to default should pop up. hit and refresh. this should help reset the network and allow multimedia messages to download.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This worked brilliantly, thank you!
さんによる
コメントを追加
How do I get the message to pop up on my screen it does not show that it pops up it just shows a red dot when I unlock my phone
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
you have to change your notification settings to allow preview message on lock screen.
さんによる
コメントを追加
MMS requires a data connection. MMS is NOT INCLUDED in unlimited talk and text plans, and will cost you overage if youre not paying for data. Make sure cellular data is on, and your APNs are up to date.
A quick google search of your Carrier APN Setting should give you what you need to access mobile data.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
MMS is included with my TMobile unlimited talk and text plan.
さんによる
no this is not true with att.. it was with sprint which was horrible but this was years ago.. i cant imagine any company today that will charge you for a picture text
さんによる
im in Canada, and our picture messages and group messages will not send if mobile data is off, on any carrier, as the images need to send via the LTE/2g/3g/etc network.
さんによる
コメントを追加
I just fixed this issue by turning off WI-FI, reboot and try again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ashannyork さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 64
今までの合計 52,678
