no sound through headphones,previously no problem.
Headphones work on other devices but not on acer chromebook CB5 311. Other 'phones do not work either.Not happened before.
First I would try the obvious. Blow out the audio input with canned air, check your settings, restart the computer, reinstall/update drivers, factory reset the computer.
If all else fails, you may have to replace the audio jack. I haven't been able to locate any guides or replacement parts for this on iFixit so I would try to google it. If for whatever reason you aren't able to fix it yourself, then take it to a professional.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
