Red standby light blinks once, TV won't turn on, Samsung LED TV
Hi there,
I have a Samsung 55" LED Smart TV, model number UN55H6350AF. The TV when plugged in, will have the standby red light on solid. When I try to turn the power on, the red light will flash once, then stay solid again. The TV will do nothing, I hear no sound like the TV is even trying to power on, nothing.
My friend took the TV to a local repair shop, and the guy figures the issue is with the LED strips and quoted a insane price to repair the TV. This TV is just two years old! I was hoping someone may have some insight to this issue so I can look for parts to repair the issue.
Thanks for your time and knowledge!
Ryan
Update (08/03/2016)
I added to your diagram to show as to what I measured, hopefully this will help you :)
Thanks,
Ryan
この質問は役に立ちましたか?
27 件のコメント
Try pressing remote then immediately block the remote signal with you hand. Tv should come on. Worked for me.
Gina Radway さんによる
@revelation since your backlight comes on when you disconnect the connector, you know that it is not the LED strips. From the voltages you list (great idea to mark how you did it) it looks like a bad main board.
Rep: 1
oldturkey03 さんによる
Thanks :) I have ordered a main board off of ebay, it should be in next week. I will let you know how I make out. Thanks again for all of your help and knowledge!
Ryan さんによる
Good news!!! The part finally arrived and I installed it and that was the issue! The TV turned right on and seems to work perfectly! Thanks again for all of your help, without your knowledge and help this TV would still be broken and possibly being recycled! Thanks oldturkey03!!!
Ryan さんによる
What was the cost of the board?
jeffdharlan さんによる
22件以上のコメントを表示
