The screen has gone completely black. Otherwise the phone is working
The screen has gone completely black. Otherwise the phone is working. Please help me fix it. Thanks in advance
Hey @shovanadhikary, there could be a lot of things that cause this. Follow the troubleshooting tips for your device to try to fix this. There is also helpful information in this post for more things you can try.
-Let me know if this helps.
このアンサーは役に立ちましたか?
Mi Redmi 2 mobile screen goes blank after some time.When i keep it in pocket then it goes blank.So i just flash my mobile with stock Rom so that, problem would be disappear.But, it doesn't work.So i flash with other Rom i.e. custom rom. And the problem solved.Now, mobile doesn't get blank.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 13,955
Have you found any solution, i have the same problem.
Gandalf さんによる
my redmi 4 mo reslove it
obile is working but ntg displaying on screen can any one help t
M.Narendra Reddy さんによる
I have remi note 7 pro mobile
It display turns to black while using what can i do can i change software
rαj mtчαmαhα さんによる
