メインコンテンツにスキップ
統合されたディスプレイを持たない一般的な据え付けのコンピューターです。
2134回答 すべてを表示
Why won't my computer turn on at all?
My computer won't turn back on because of another user restarting it twice in a row. I tried replugging everything and turning the main power off, I am low on money so I don't think I can get professional help to fix it. My computer is an HP, and has been used for years. Anyone know how to get it to start?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hello, what's the model of your computer? Any beep codes? Does the fan spin When you hit the power button?
If you hit the power button and the fan spins, your CPU/RAM/Bios may be failed. If you confirm bios is dead, you need a new motherboard.
If nothing happens, most likely because of a dead motherboard. But I see you are low on money, go to amazon/ebay and see if there's still some motherboard that are compatible with your cpu.
If CPU/RAM died use the same solution that i said for the dead motherboard, i think it doesn't costs you for over $50.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Also, if the fan doesn't spin, then it's probably the PSU.
さんによる
コメントを追加
回答を追加する
Debra renfro さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 96
