1.6または1.8GHz デュアルコアプロセッサー、 2GBまたは4GBのSDRAM, 64GBまたは128GB SSD
190の回答 すべて表示
Coffee unaffected logic board sticky non-funtional keyboard
I have managed to spill 1/4 cup of coffee (no sugar) onto my MacBook Air keyboard.
The computer is functioning fine except the keyboard, most keys not responding and it turns itself off, shift and cantle key get stuck. I am using bluetooth keyboard for now.
After I bought the pentalope screwdrivers and took apart and checked the back of computer and the logic board, it appears that liquid did got there.
Is there a way to clean keyboard without re-soaking in water and drying? What is the best what to clean it?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
We really need to know which machine you have to give you a competent answer . Please go here and enter your serial number and let us know your findings. http://www.everymac.com/ultimate-mac-loo...
による
I have Mac Air 11" mid-2011.
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
選択されたソリューション
There is two ways you can attack this the quick easy way, but expensive or the hard way which would be cheaper and may not fix things.
The easy way is to just replace the MacBook Air 11" (Mid 2011) Upper Case with Keyboard following this IFIXIT guide: MacBook Air 11" Mid 2011 Upper Case Replacement
Or the hard way is to follow the same guide as above but take the keyboard apart to manually clean things with distilled water and a good grade of isopropyl alcohol (85% or better) to help dry things afterwards. Here's a Vid on the process: Replace liquid damaged keyboard of 2011 Apple Macbook Air. Even after cleaning you may find things are to far gone to recover the keyboard.
MacBook Air 11" (Mid 2011) Upper Case画像
製品
$99.99
この回答は役に立ちましたか?
スコア 3
コメント:
I am taking it apart. I will let you know how far I will take the disassembly. Thank you for the advise.
による
I needed to buy keyboard backlight ($20 on ebay) instead of new computer as suggested by Apple sales tech. One weekend of tinkering. Thank you for such in-depth guides.
による
コメントを追加
回答を追加する
spylaw01 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 119
