Can my cracked screen be fixed
Samsung s6 active
Cracked screen but everything else works
The S6 Active inherits most of its hardware components from the Galaxy S6, including an identical octa-core processor, 3 GB of RAM, and a 5.1-inch display. It uses the same display type as the S6, and has a 16 megapixel camera. Its hardware design is similar to the S6, except it is slightly thicker, has metallic rivets, and uses three physical navigation keys instead of a physical home key and capacitive back/menu keys like the S6.
So the repair should be very similar.
Possibly traci @kaniggit49 or
can tell you if it uses the same glass.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 597
